Help
cdneri
I'm not a GN guy (wish I was) but I do need some turbo help. I live in the St. Pete/Tampa area. I have a factory turbo from a Subaru STI that has a broken stud. I need to get it removed/replaced. Anyone know of anyone that can do something like that in this area? If you have any suggestions, let me know. Thanks!
Craig
good one Mark
depends where it is broken
if it is broken off flush you will need to get a good ez out. but you will probably need to heat it up.
if you have nub get some vice grips.
also heat it up prior.
i would suggest pulling to turbo off to do so.
good luck
If you need to take it to a machine shop, try Southern Style Racing engines in Pinellas Park 727-546-7000
