Kinda weird, but when i go into boost at around 10-14psi, it sounds like the boost or turbo sputters. Dont know exactly how to explain this, but when i put my foot down, the boost hits rock solid after 14psi and before 10psi, its that in between point of 10-14psi that i notice this. I noticed this when i loosened the rod to adjust my boost controller. When i turned up the clicks on the boost controller, i set it to about 22-23psi of boost, and then i noticed when i took it for a run it kinda sputtered bad and would actually make that funny sound when you let off the gas while running boost, that sound i believe comes from the K&N filter as soon as you let off the gas from boost. Anyway i turned the boost controller knob all the way down to where i was just bleeding pressure from the rod again. So now i got the rod doing all the work again and set around 22-23psi and it kinda went away. But im still getting a little bit of fluttering between 10-14psi until i nail it, then it completely goes away. And it doesnt do it when im building boost right up to 10psi.
Sorry for the long thread, but im not sure how to explain this, hopefully some of you guys can catch on to what im trying to say.
thanks
jojo
thanks
jojo
