I think your rite, 7.3 with 98 = 11.25-11.33 at 120-122 comfortably.
A couple things I have noticed have changed. One is the amount of alky i'm blowing through the motor is huge. I mean huge. I'm going through a lot. And it doesnt seem to complain. The 98 run I looked at the guage it was at 24 PSI through the traps. Tho my MAF readings are getting rippling due to the amount of pressure i'm drilling into the motor. So a sensitive MAF like an LT1 may or may not be beneficial.. I need to do some research.
Basic formula take fuel out, add alcohol.. works. But becuase the pump is pressurizing the intake tract. its a wonderful thing
Last nite I could hold 15 PSI at the line before it blew the DR's. It was just too much pressure on a set of $hitty tires.
And I found my problem, its the tranny. See I always raced my car leaving in 2nd..shifting to 3rd. Well further research.. what happened is my tranny when I put it into 2nd gear... is in 2nd, not 1 st. So when I lock the converter at the line, the car was trying to build boost on a locked converter... at 2400 rpm's it was done. So last nite I was racing the car in Drive and letting it shift by itself at 4800 rpms. Shifts are beautiful.. I aint touching that tranny. It wasnt weather, or ??? its the tranny.
Solutions shift manually 1-2, 2-3.. or let it do its job. I may just mod the governor and up the shift point to 5300 since a cam is in there. I'll screw with that next month.
I tried 15 PSI in the rite air bag last nite no change. car ran a couple 7.3's then went to consistent low 7.5's with 1.85-1.90 60 foots. Made like 7 passes in 2 hours.
