New Best at Cecil this past weekend !!!
Guess it's time to fill in one of these :biggrin:
New Best
Cecil County Dragway, MD "Test & Tune" November 28th, 2009
Details of the run:
60' 1.533
330' 4.526
1/8 7.079
mph 95.82
1000' 9.300
1/4 11.186
mph 119.73
Best 1/4 MPH to date:120.18
Best 1/8 MPH to date: 95.82
Best 60' to date: 1.533
Scott89TTA #1376
EMPTY WEIGHT: ~3400 (estimate)
BLOCK: STOCK
HEADS: STOCK (matched intake gasket while changing head gasket)
CAM: STOCK
TRANSMISSION: Anderson Performance. built BRF 200R4 w/billet internals & Stage-Rite trans brake
TORQUE CONVERTER: TCS Billet 9/11 3400-3600 (manually locked in 3rd ~95-100 mph)
DIFFERENTIAL: STOCK
INTERCOOLER: STOCK
THROTTLE BODY: STOCK
RJC POWER PLATE: YES
INJECTORS: Siemens/Mototron 60 lb
THERMOSTAT: 165 DEG
TURBOCHARGER: Precision GT6776e
VALVE SPRINGS: John’s Performance 100 lb.
MAF: LT1 w/Translator
DOWN PIPE: 3” Action Fabrication w/Mease THDP style elbow
EXHAUST: STOCK w/3” QTP electric dump (OPEN)
FUEL PUMP: WALBRO 340 w/Racetronix Hot Wire kit
FUEL PRESSURE REGULATOR: ACCUFAB Billet
FUEL PRESSURE: 42 psi w/line off
ALCHOHOL INJECTION: YES, ALKY CONTROL
PROPAIN INJECTION: NO
NITROUS: NO
AIR FILTER AND AIR INTAKE: GRUMPY 3” MAF Pipe w/K&N X-Stream 8 11/16” RX-3990-1
TIRE DESIGN, SIZE & AIR PRESSURE: Mickey Thompson DR’s, 255/50-R16, 16 psi
AIR BAG(s): NO
SUSPENSION: STOCK (original)
SCAN TOOL: Scanmaster w/fast update chip and Powerlogger
FUEL: 93 Sunoco
CHIP: Turbo Tweak Alky
CHIP TIMING: 21/23
KNOCK RETARD: 1.8 deg on converter lock in 3rd
OXYGEN SENSOR VOLTAGE: 790-764
EXHAUST GAS TEMPERATURE: ?
TRACK ELEVATION: 320 ft. (Cecil County Dragway, MD)
TEMPERATURE: mid 50’s
PEAK BOOST: 25.7
BOOST AT LAUNCH: 12 w/Trans Brake
MILES ON THE CAR/ENGINE: 50K
-Scott
I bet your car weighs more than that. Mine weighs 3770 with me in it. I weigh 165ish too. Congrats on the runs. I know exactly how you feel!
Jason
Mine without me in it is right at 3500 with maybe a 1/4 tank. I weigh 240+/-
Jason
Yeah that is only a guess based on threads from the past "what does your TTA weigh? " Seemed like a lot of bone stock TTA's were right around 3400...I'm close to 200. My car does not have any weight reduction nor does it have any added weight items like sub-frame connectors or roll cage. So I figured it was close...Razor's car was 3600 empty & 3850 w/driver...he had a cage and subframe conectors...that has to be at least 100+ lbs I would think.
Seems like every track I go to the scales are down :frown:
Pulling 1.50's 60 foots I would seriously think about some sub-frame connectors. And start planning on which new rear end your going to install.:cool:
Michael
yeah...I plan on doing subframe connectors and I'm sure a rear is in my future as well :cool:
I have a set of tubular lower rear control arms at home I need to install as well...winter projects :)
Scott
