I have used the Caspers version and it truely is plug and play, easy to install since the toggle switch and wiring unplugs from the larger plug in connectors that go to the A/C switch on the high side near the compressor area.
Easy to locate and run the wiring from the toggle through the dash to the underhood wiring.
Here's a link to the Caspers' unit which incidentally appears to be cheaper.
