Hi-Lo Cooling Fan Switch
84GNwith87eng
Has anyone used Kirbans Hi-Lo fan control switch?
If so, was it hard to install? Its part # 6878 on the website, lemme know if you've had good luck with it.
Chris ;)
Looks a lot like the Caspers plug and play unit.
I have used the Caspers version and it truely is plug and play, easy to install since the toggle switch and wiring unplugs from the larger plug in connectors that go to the A/C switch on the high side near the compressor area.
Easy to locate and run the wiring from the toggle through the dash to the underhood wiring.
Here's a link to the Caspers' unit which incidentally appears to be cheaper. ;)
https://www.casperselectronics.com/...Screen=PROD&Product_Code=102044&Category_Code
You do need a hole in the firewall or rubber boot large enough to get the plug in fitting through which is about .3"-.4" or so in width.
Wire harness itself is about .2" in dia. or so.
