High Beam Lamp Assembly H4 Bulbs BOSCH
GNVenom
Here's a pair of glass lens bulb housings for the inboard (HIGH) beam on your GN. They use H4 bulbs, so you can wire it to blast the high beams with both filaments - or - add LED or HID H4 bulbs to make a killer high beam system. These are high end OEM NOS bulbs.
Bolts right in to your existing headlight buckets. $75 for the pair.
