BLACK6PACK
1 sec reaction King
- May 24, 2001
I have whats in my sig plus the SMC alky kit. I am just starting to dial this combo in. I went out and made a couple of short blasts to about 70 mph. I have the Max Effort also. With the setting on 4 (fairly rich/low timing) and boost at around 21 psi ( had to turn it down due to knock) I was getting super high egt temps. Thats the reason for the short blast. I've got the dual nozzles on the smc, had the pump speed at max and turn on around 12. I was seeing EGTs as high as mid 1700s. O2s were low 800s and 0 knock. If I turned the boost up any higher I would get knock. With the single nozzle setup, I was running a RA 100 chip at 23-24 lbs of boost. Whats up with the high EGT?
Also, does alky go bad like gas does?
