zapp240
- Mar 17, 2016
Hey all, recently purchased my 87 GN and am in the process of getting the car back to a street friendly driver. The car was pretty much clean and road ready when purchased, but was set up more as a show/ occasional strip car. I have replaced the red armstrong R106 chip with a TT chip for 93/94 octane. gave Eric the known spec as well i could, (ta 62- 3"rjc dp- slic upgrade- new tank hot-wire and fp but not sure what type- unknown internal motor upgrades- 42.5# injectors- hooker cat-back exhaust- kn intake) now the issue i am having is , as stated on the chip install, cant get the pressure below 50psi. thought it may have been the holly adj regulator so swapped out with an accufab adj and get the same results. the lines look in excellent shape. I have searched the other threads and came to the conclusion that the return line is probably the culprit, so my question i have is are there any known weak spots i can check before looking into replacing a very good looking return line?
