High fuel pressure..
TT/Ameasap
The White Blur
My 02 readings have been lean ranging from 720-780 I have thrasher 92 chip and it calls for 45psi line off. I have a cheap fuel pressure gauge and line off it reads 52psi :eek: Can the FPG be off that much? or is it 02 sensor? Because all was well before and now all of a sudden this lean cond. has occured :(
I really want to know if I can bump fuel pressure even higher to see if 02's raise with out hurting anything to see if it is the FPG thats funny:confused: Is that OK?
Well, I was just out after bumping the pressure a little and now 02 are looking good! 780-820 range hmmmmmm... I guess I will leave it there until somthing tells me otherwise. oh,I did forget to mention that I removed a MAF screen. I wonder if that cause this lean cond.
Anyway thanks Kevin,
Bo
Ok, out again and 02 are bad again 690-730 this sux!:mad:
So, what do I do with this $130 billet AFPR then? Just chuck it?
Anybody else
Bo:mad:
