TurboBrett
Mr. Bump
- May 24, 2001
I failed the two speed idle test here in texas because my hydrocarbons are too high at idle.
Can I realistically get these lower at idle without a cat?
See my sig for car setup. Since I have the ability to tune via the translator Gen2 i'd like to try that before adding a cat since that requires much less welding![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Results from test:
High speed
RPM 2471
HC(PPM) 85 PASS
CO(%) .89 PASS
CO2 (%) 13.7
O2 (%) 1.0
NOx(ppm) 0.00
Dilution (%) 14.6
Low Speed
RPM 0929
HC(PPM) 585 FAIL
CO(%) 1.08 PASS
CO2 (%) 13.2
O2 (%) 1.7
NOx(ppm) 0.00
Dilution (%) 14.3
Results from test:
High speed
RPM 2471
HC(PPM) 85 PASS
CO(%) .89 PASS
CO2 (%) 13.7
O2 (%) 1.0
NOx(ppm) 0.00
Dilution (%) 14.6
Low Speed
RPM 0929
HC(PPM) 585 FAIL
CO(%) 1.08 PASS
CO2 (%) 13.2
O2 (%) 1.7
NOx(ppm) 0.00
Dilution (%) 14.3
