Randy Hagins
- Aug 5, 2002
For some strange reason when I hook up my OTC 4000E to my "86 GN, My car will go from around a 550-600rpm idle to about 1000 rpm's once the OTC starts reading data from the car. Once I disconnect the OTC the car goes back to normal idle. I was able to set the IAC while the IAC was disconnected using the OTC. I set the IAC counts to 35 to 40. And I set the rpm's @550. What is the deal? Anyone know?
Also, what wire on the ALDL do I use for the TCC lock up?
Thanks for the help if anyone can!
