Darrell1987SS
- Mar 3, 2008
I'm having some issues with a newly rebuilt 200-4r.
It's an 87 CZF from a Monte SS with the BRF valve body. During the rebuild, a "Superior 200-4r HP" kit was installed. Currently it is installed in the frame (no body) so I can't apply brakes or do any loaded runs, so all pressure testing is with the wheels in the air.
The bad signs that something is not right are:
1. The line pressures are around 225 in all ranges including park and neutral and are not effected by the TV cable position at all.
2. When D4 is selected, the engine seems to load down at idle, but some additional throttle will spin the tail shaft (this doesn't happen in R,N,D1,D2,D3 although in D3 I though I heard some type of "chatter" at one point.
3. No shifts seem to happen in D2, or D3, (haven't reved the engine in D4 becuase of the loading issue #2) but I haven't pushed above 2,500 3000 RPMs since the engine was just broken in and I didn't expect much with the high line pressure.
Reverse and neutral seem OK as far as direction of motion or no motion. D1 and D2 give forwared motion, although I can't exactly tell what gear it is in (I don't have the speedo hooked up), but by eye I would say it's one of the lower gears.
Things I've tried:
1. Removed TV plunger and checked for free movement of TV valve (seems like roll pin is in the correct valve "slot"). Motion of plunger seems fine with cable action.
2. During the rebuild, I left the exhuast checkball in place (maybe not the best thing). From what I can tell by pushing a small wire into the hole, it is free. The pin for the TV cable failure safty seem to move into the VB correctly so that the checkball would be unseated when the TV lever touches the plunger.
3. I pulled the regulator/rev/boost value out of the pump to check for binding or improper intallation, but that seems fine.
I'v read that a stuck slider guide can also cause pressure issues, the pump was converted from a 7 vane to 10 vane setup with new rotor and vanes, but the origial pump housing and slider guide was reused. The rotor was compared to the original with a micrometer for proper clearance.
I'm not sure if high line pressures should cause my D4 issue, so I'm open to the idea of multiiple issues.
I'm looking for anything else to check before or after I pull the tranny.
Any thoughs or ideas would be greatly appreciated.
Things I've tried:
