im going to change my oil pump over to a hv pump. what spring do i use the 40, 60, or 70 psi spring. the how to build buick engines books by Jefferson Bryant says "do not use the 60lb spring, because it is wound too tight. the coils tend to stick and bind before the relief valve can fully open, causing your pump to build oil pressure well over 100psi. this high pressure oil will cause your cam to float in the bearing,knocking on and destroying the bearings. most builders recommend a rebuilt pump with a minimim of 60lbs of pressure" (buick engines pg 36) he say that last line in the book so what spring do i use. if you have the book you can see it exactly.
