SignUp Now!If the clearances ar right, a high volume pump is not needed. Just puts a lot of stress on the cam gear especially when the motor is cold.
I tried to find out why this guy asks about a high volume pump. Actually, I knew what the consensus would be from all the "experts". Let's see, if everybody does their homework, they're not needed, andMany fast cars use an Earl Brown modded cover. What about cars with 150-200K miles that runs great but idles around 5psi? Should he suddenly rip his engine out, or suffer with 40 lbs of oil pressure at WOT? People like to talk about stock oil pumps that have gone 8s, but they forget to mention the thousands of dollars of modifications that make it happen, and maybe not that the oil pump is modified. And then there's a bunch of people who just agree. Everybody ... no scratch that ... most people here aren't interested in pulling out their motor because maybe it has some miles on it and the oil pressure sucks. Depending how you use the car, maybe it can't be saved. Maybe that rebuild can't be put off, but hey, I'd just switch out my main and rod bearings, but plenty of guys don't know how to, and it's cheaper and not as complicated to have a HV pump installed than have some mechanic whine about how difficult and costly it is to switch bearings. So, for you ace mechanics, or people with too much money, go ahead and make the mods you want to make your engine perfect so you can shoot the breeze with the track dogs. Nothing wrong with that, but for you guys who can't change your oil or aren't interested to, or are certainly not interested in pulling your motor or replacing your bearings, HV oil pumps work. They are not a bad thing, but you'd never hear that from the "experts". Every TR isn't a race car. If your oil pressure is $hit, a HV pump will most probably lengthen the life of your motor if that's what you're looking to do, and perhaps you'll never have to bring it to your friendly machine shop so he can @#%&! you up the &^%$.
You have some good points but I will disagree.An oil pump will not fix a worn out motor period.Look at new cars oil pressures over the years have been reduced,for many reasons.High oil pressure does nothing for a motor but consume power and put strain on certain parts like pump gears and dist gears.
High pressure will actually hurt engine life as the oil goes past the bearing too fast and does not take the heat away.GM spent millions of dollars designing these cars so we can just increase things for no reason.
I am by know means an expert but this is a no brainer.:biggrin:
Kevin
The Biggest Problem is Many Aftermarket covers have Alingnment issues with the Cam sensor. Sometimes they wont line up properly, sometimes they wont even drop in at all! The Earl Brown mods to a stocker with a clean pickup tube will bring up enuf pressure that if that it doesn't work, then you need internal work done. Nothing fixes that!
