I was checking the recipts the previous owner of my car gave me, and noticed he installed a high volume timing cover. Now, i just changed the oil, and put in 5 quarts of mobile 1 10w30. it idled low, at around 10psi. I then proceded to check the dipstick after letting it sit for a while. The oil was just over the line of the "acceptable" area with the little hatchmarks. I kept adding more oil untill the level on the dip was right around normal, toward the top of the "acceptable" area. now(checked after running and letting sit.) now at startup, pressure jumps high to about 30-40 and eventually settles, kinda scared me when i saw that since im used to the low idle. does that highvolume timing cover require more oil? or is it just throwing off the readings on the dip?
