hobbs switch
I use the motor. Best when its running.
I tapped into the line going to the charcoal canister...just make sure you tap the line in between the motor and check valve.
I am looking for an adjustable Hobbs switch. Most of the switches that I have seen are fixed. Any ideas where I can purchase one?
Thanks,
Jeff
Napa P/N 701-1608. This is an old P/N but it may still be good. Note: Use to break the ground only! Otherwise you will blow fuses. I found out the hard way.Howard.
Thanks,
Jeff
Most are adjustable. Like the one pictued in this thread. You just pull out that little rubber cover (on the upper end of the one in the picture) on the end, there's an adjustment inside, takes a fairly sizeable hex wrench.
