Holds 1-2 shift @ WOT, 2-3 at partial throttle, shifts if I kick the throttle.
kenny
No turbo, no care.
Just like the topic says, my tranny will hold the 1-2 shift every once and awhile at wide open throttle. I have to let out and kick the throttle to get it to shift.
If I'm just driving around, normal driving situations, it will hold the 2-3 shift until I kick the throttle.
I'm assuming throttle valve? What's the fix, how easy is it? I would guess just pull the valve out and polish it? Where is the valve located?
Anything else that would cause this?
I'm to the point that if the car wasn't a street car, it would have a TH400 in it. :mad:
And this is after Vince Janis "repaired" it? You sure you're not doing someting wrong there Kenny?
Lemme talk to Lonnie...:rolleyes:
If driving it is doing something wrong, then, ya, I guess I am. I drove it all the way home, perfect shifts. Take it to the track, first pass, holds the 1-2. :mad:
I talked to Lonnie about it, he said to call him the next Monday (whichever day I called).
I called that Monday and got no answer. I've been trying to get ahold of him since.
Unfortunately, that is a problem where the car has to be left with a transmission guy. He needs to be able to drive it and to be able to open up the pan/valve body to do fine tuning. If however it is your daily driver, your gonna have to find another means of transportation.
Lonnie will become more accessible in aobut 2 weeks.
I have no problem dropping it off. Just name a date/time.
It would be nice if it's done by the 31st (for BPG @ Norwalk)... but not THAT big of a deal.
