Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
I'm not sure how many people on here has purchased a Holley EFI ECU that also bought a Pro Dash along with it, I figured I'd share a few custom backgrounds I've made for the Turbo Regal's. I see most people on the internet "settle" with the default layouts that comes with the Holley dash. These particular gauges include a larger analog boost gauge, an analog AFR and Closed Loop Compensation gauge. The backgrounds are downloadable and free. If you have a specific logo request, let me know and I'll try to suit your needs and put one on for you. Again, for free.  Also, I'd rather stick with putting custom logos on the backgrounds I've already created. An "all new layout" requires a tremendous amount of time setting these up. Changing logos, moving logos and changing gauge symbols is really easy to do.  I will add more backgrounds to this thread as time goes on. One more thing, I "think" these will also work on the DD-EFI digital dash too.
Some things to note:
1: You will have to set up all of the gauges manually... yourself, which is a bit time consuming. I will not provide the "automatic" set-up file for these backgrounds because I don't want to be responsible for any gauge settings that could possibly make your engine blow up. It is extremely important they are set up accurately within the gauge settings on the dash.
2: These backgrounds are not supposed to have the border or "beauty rings" showing around the gauges. Holley does not allow less than a full 360* circle for them as of this post. You can turn them off in each gauge settings.
3: Due to the inconsistency of this site not displaying pictures sometimes, and not being able to edit your posts, a link in my signature will take you directly to Google Drive where you can download them if you're interested.
FREE Holley Pro Dash 12.3" Custom Gauge Backgrounds
EXAMPLE of above background when you get the gauges set up. The warning colors, settings and TIC marks can be adjusted to your personal taste.
