Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
I see you're going to be spraying all 12 injectors at WOT but only be running on 6 during street driving. Are you going to have the computer provide the decrease in injector pulse width when the second set is turned on?
The way I have my system set up is I'm actually running on 87 octane up until 13lb's of boost. After that the second set of injectors turns on and the first set turns off. The second set uses 116 octane fuel for high boost race/street driving. You could use small injectors for street driving on 93 octane and then under boost switch to 160lb injectors. That way you don't have to put race gas in both tanks. I have talked to someone that says doing it that way is possible with aftermarket fuel management. I may end up with different size injectors in mine before long to see how that works.
Here's the whole story on how I have mine operating. Click here
