Home for the track again
crazygn
10's here i come
It's a good day i took the car to the track tonight
Tmes for tonight
First run i red lighted trying to build to much boost [ no time or speed]
2nd run was with 19-20psi and spun tires thu fist
60' - - 1.94
330'- - 5.49
1/8- - 8.43
1000'- - 10.93
1/4- - 13.05@ 107.4
3rd run 23psi
60'- - 1.82
330'- - 5.27
1/8- - 8.14
1000'- - 10.58
1/4- - 12.65@106.1
Speed droped from 108.5 to 106-7mph but a better time
This is still not tuned but no knock at 23psi
:D
I found that when i raced it i had a crack in the #2 cyl header pipe.
If i can run 12.65 and 108.5 mph untuned, what can it get with the new set up. I am getting ready to add a 3000-3500 stall, 50 lb injectors, and a ta 54 turbo with a scan tool.
What kind of power or times should i get close to .the 12.65 was with the set up at the bottom with the ta33.
