I was talking to Bruce (WE4) from Performance Trans last night about problems with my trans and we got talking about the turbo and overboosting. He asked if I had the correct Y fitting going to the turbo, Bingo No I don't. He said that the Y has a reducer on it, I have a T connection with no reducer and I replaced the vac lines with 1/4 in. heavy fuel line too.
Ok so if I want boost control all I need is a air valve with a fine adjustment right? Run the lines in to the cab and mount it on the dash so that I can adjust it from inside.
I have read FC227 (Fred) talking about a boost control on his, but I can not find anything on how he built it. I checked B4Black's web site & Fred's with no luck
Ok guys/gals lets brain storm and build it. Oh I can boost up to 13-14psi before I start to lean out.
P.S. my trans is tired
18 years old w/out a rebuild I believe.
