Mike T
- May 3, 2013
I have read about cylinders distorting after the heads and main caps are installed. When my block was bored/honed we did not use torque plates because this was going to be a "get me by motor" until I build my stage II block.
I still have not built the other motor and this one is now leaking water so it needs to come apart. Since I didn't use torque plates I am curious if there will be high and low spot that show up in the cross hatch. It never had any oil consumption issues or blow by and the motor still has very good/even compression.
I know using torque plates is the correct way but is it really necessary and do you think I will see the cylinder distortion in the crosshatch ?
