Squid4life
- Jul 5, 2004
I pulled my hooker cat back off to install a single shot. When it was installed it was welded instead of clamped, so I carefully used a chopsaw to cut it off at the mufflers. It has stailess/chrome tailpapes and it is in good shape. No rust through or holes, just some baked on tranny fluid and oil from my previous motor. Could used wire brushed or pressure washed. Would need a little work to get back on, either rewelded, or slip fit/clamp fittings. I can also throw in 6 2.5" 3 bolt collector style adapters if you want to weld it back together that way. The box weighs about 80lbs, so it'd have to go UPS. I am guessing shipping would be around $80. I may be able to deliver it to Kansas City, MO, or anywhere between Wichita and there.
Asking $100
Asking $100
