I am putting an amp in the trunk and want to run the POS wire directly from the battery. I bought an in-line fuse holder to go between the battery and the POS wire that will run to the trunk.
What is the best way to connect the wire from the fuse holder to the POS battery post?
1) smash the strands under the post when I tighten it down?
2) put an aligator clip on the end and clip it to the post?
Does anyone make an adapter that hooks to the battery and then the wire to the adapter?
