How do you guy's route your vacuum/boost line to the Map sensor?
The way mine is setup, is i start from the manifold with a 3/8 id hose to a "+" fitting that feeds the fuel regulator, The mondo Bypass valve, and finally the MAP.
Is that ok from your standards?
When i was running a stock computer with PMS, The map was hooked the same way, and was reading the same as my boost/vac guage.
Now, at idle i see ~10inHg vacuum, but in the Calmap software i only see ~5inHg.
Should i separate the MAP vacuun line from the others?
Thanx
Thanx
