At least with mine, the metal/aluminum aftermarket vacuum block ports were spaced closer together than the original plastic unit. I do not know why they did this, but I know I could have used a few mils extra space between each port.
Take the block with you. Those guys at the Auto Store say they are giving you vacuum line, but I found most are actually fuel/emissions hose. I guess it saves a few inventory bucks using this "Dual Purpose" rubber tubing. In most cases, I suppose this works fine.
The sizes may be the same (Ex 7/32" inside diameter) but the fuel/emissions line will have a thicker side wall than REAL vacuum tubing, causing a fit problem in this case.
Hunt around for the real deal vacuum tubing. I think you need sections of 7/32 id, 3/16 id, and 3/8 id if I remember correctly.
You can use the emission hose if you are handy with a blade... Cut "Flats" on the outside of the lines to give you enough room, That, and some liquid soap lube!
