Hot air parts Needed
John Pearcy
Hi folks, I need the following "STOCK" parts for a 85 car
1) Both the feed and return fuel lines (Filter to rail and reg to frame)
2) Down pipe
3) Turbo charger main mounting bracket (2 Piece's) AKA Turbo/Intake Heat sheild assy.
PM to johnsperformance@comcast.net
Thanks!!!
John Pearcy
John,
I have a low mile hose left over from an 85 to 87 conversion, but I don't remember which one it is. It is a rubber hose with metal ends. Is this one that you need?
Doesn't sound like it, the feed fuel line is all steel, the return line is steel but with rubber at one end.
John
John, I looked at my fuel line again and I do have the filter-to-rail which is a hard line that is detachable from a rubber line. Do you still need this?
John, I might be able to help you out with the dp & turbo bracket. I have a friend with a H/A parts motor. I'll check on it and see what he has.
