I have just removed all these parts from my car. I'm swaping to a fast stand alone system and champion intake and no longer need these parts. Everything is from my 86 t-type WH1
Complete engine harness
Injector Harness
battery cables
stock Lower intake with coolant sensors, radiator neck and clamp
stock upper plenum
stock throttle body
throttle cable, bracket, kickdown cable and cruise control assembly
stock fuel rails with stock regulator
coolant rails with valve and hoses
stock coil pack with accell plug wires
cam position sensor
crank position sensor
stock headers, driver side was cracked but has been tig welded
stock turbo
misc. vacuum lines, sensors and valves.
No intercooler, ecm or coil pack bracket
I would like to get $750 for everything. I'll consider parting it out in a couple weeks if no one is interested in the complete kit.
Injector Harness
battery cables
stock upper plenum
stock throttle body
cam position sensor
stock turbo
