I guess this is mainly for TTA89 & cool84.
I was helping Sharif tune his 85GN. He had the wastegate tightnened all the way down. With a hypertech chip, the factory boost gauge was saying 13psi with pretty lazy spool up. We switched back to the factory chip and it was down to 9 psi. He was convinced that his boost gauge was worthless, but he had plenty of threads, so I convinced him to try and cut 1/4in off the end. We did, guessed at where the rod should be, and test drove. 0 deg Knock @8psi, so two turns on the rod, and test again. O deg knock, two more turns on the rod, no knock. We kept going back and forth - shortening, testing, shortening, testing, until we had maxed the rod out again at @ 14psi. O2 @ .95-1.02mV. Soon, Sharif will thread the rod out some more so he can get some more turns on it. Not to mention that spool up is a lot quicker.
Anyway, we ran a little bit on the highway when it was finally time for me to go home. He was in front, so he turned onto the highway first ahead of me. I think he waited until I was fully on the highway to go WOT, but I pretty much did the same at the same time. I pretty much went by relatively easy from @ 1.5 lengths behind him to maybe 1 length ahead. Not exactly flyin by, but not too hard either.
This is on mostly stock cars, and with more boost, the 85 should run faster. Just thought I'd share anyway.
