hot air w/ power logger?
I have a hot air with a powerlogger. Send me your phone number and I can answer all questions. I will send you my number as well. Brad
well! i guess getting some help putting it in won't be a problem! thanks, guys.
Been runing mine since around Nov 2006. No issues.
power logger w 84/85 ecm
Forgot to ask if the power logger works w/ my 84/85 ecm!
damn!!!!!!!! means i got to work! I will have to upgrade my injectors to 37# with tt chip and ecm. Hey! at least I learned about cutting out the hole on the turbo mounting bracket; to help position the oil return. Thanks again, hot air buddies!!!
Hey brad I just got my tt chip for 60 #'ers just have to install iat sensor and i will give you a call; I will finally be able to run powerlogger. I've been itching to use it.:cool:
