I've seen a bunch of posts on how to use these with the stock actuator, but how can I use it with my Racegate?
Right now I've got it connected to a small air compressor regulator and can only get 17psi max with a 9lb spring in the Racegate. I used to have a Deltagate and this setup worked fine for 22psi and then some. I'm guessing the regulator isn't pushing enough air through for the Racegate. I got a Grainger valve based on recommendations in an earlier post.
Thanks for any replies.
Mike
Mike
