saw the buggy on another thread....
....and that looks to be fun to zip around in. Light weight and turbo'd...I'm sure it surprises a lot of people.
I'm probably going to have to stretch or add a stiffer spring. I've now tried both approaches to increasing boost. I started out with having to only pull on the actuator rod and 1/8" to attach to the WG arm, turned in the boost controller all the way and got a max of 18#'s. I then did the opposite, adjusted the stock actuator to approx 18-19#'s then started out with the boost controller adjusted to only one ot two threads and started going up from there. I'm now 5 or 6 turns clockwise on the boost controller and still no gain in boost.
Time to either stretch the spring or go heavier on the spring. I'm open to any and all suggestions.
I've used this Grainger check valve (about $10) since Feb. on my turbocharged VW air-cooled motor.
It's allowed me to get 18 lbs. of boost out of a wastegate actuator that's set up for 10-12.
Set-it-and-forget-it accuracy and repeatability.
I couldn't be happier.
As for tuning it, I started out with zero tension on the spring/poppet ball and slowly tightened it to increase boost.
Personally, I wouldn't go trimming the spring.....I think it's good for 0-20 PSI right out of the box.
Bill
