i think it is like a few extra dollars on the same site...What 3" pipe do you have? Lee's? Do you need the exhaust elbow? I have the mease pipe, wich eliminates the exhaust elbow. I am unsure if the hot air elbow will fit any other model turbo, but if it does, I have a high-temp painted silver elbow if you end up needing one...Just pay for shipping!
I didnt read your mods when I said about the porting, but i do know this, you should at least gasket match the ports and the intake hump where the air goes in, should be either ground to a point, or smoothed down real nice for the better flow.
you seem to have a nice combo so far! What about a chip? Upgrade teh eletronics? Tires??? Those a re pretty imortant when pushing deep 12's and even 11's. Any work done to the trans?
I got a roller motor on the way, fully ported heads, fully ported intake, 3400 stall converter, considering DYNOTECH trans overhaul, 87 ECM, 87 Coil, walbro 340, 60lb injectors, Mease 3" dp with dump, atr 2.5" Up-pipe, ATR Raim Air with the 8" filter, lt1 maf, alum radiator from 90's camaro, eletric fan from GN, trans cooler, oil cooler, and I havent even gotten to the tires yet.
I have to wait for my flow numbers before I pick my turbo, thanks to some very healty info from a very reliable source!!!
Do you have flow numbers?
Many of the parts I have are sitting in boxes, or on order, waiting for $$$ from me! lol....I am a senior in college, and I am getting married in june, so the priority list sits the GN at about 5 or 6, not #1.....needless to say, I need another 12 months or so to have a running T-Type, let alone, an 11 sec car that I am trying to achieve. But, of all goes well! 11's are in sight!!!
John
