how do i make an air intake?
Those will work fine Socal. When you put it together, remove the bracket that holds the mass air flow sensor. Not needed with a hard pipe, some say the vibration kills the sensor anyhow.
I prefer the AFE Pro-Guard 7 filters over the K&N filters.
http://afepower.com/technology_detail.php?tech_id=6
I used to run K&N filters on everything that I owned until I found a fine layer of dust on the downstream/clean side of the filter & intake tract. So far I have not experienced this with the AFE.
~JM~
