How do I replace the stock radio battery?
gnX405
Got a stock radio that has been sitting for awhile without a voltage source. Now even with a fresh car battery the clock in the radio looses it's memory.
How do I replace the battery that is built into the stock radio?
P/Ns, battery sources, instructions would be greatly appreciated.
-john
-john
I would check the fuses,,the stock radio doesnt have a battery back up,,there is a seperate wire from the fuse box that has power all the time ,,for memory...
Thanks for the pointer.
I wasn't sure if there was a separate battery or not.
-john
That fuse he is talking about is the domelight/cigarette fuse but I think if that fues were blown than the radio will not work.
Does the domelight work?
Not sure if the domelight works or not. It's not my car but a friends.
Thanks for the info.
-john
Fuse
If it is not your fuse,check your wiring.You may have the 12 volt switched power and the 12 volt constant backwards.
