Mar 1, 2009 #1 T TWISTER Member Joined Mar 25, 2003 Messages 790 I bought a t type that is grey and it has a older repaint and even after wax it feels rough and some scratches are still there, Is there a way to remidy this? Clay bar? Ive heard of wet sanding or color sanding but dont know how. Any advice. Thanks.
Mar 1, 2009 #2 GNBRETT Pelennor Fields Joined Feb 8, 2004 Messages 15,860 I would not recommend a wet sand on ur own if ur not familiar doing it. I would definately start out with a good clay job tho.
Mar 2, 2009 #3 W whitecobra98 Member Joined Dec 6, 2006 Messages 738 if u can use silly putty, you can clay bar your car...super easy...i use Griots Garage clay bar
Mar 22, 2009 #4 J jrhanulec New Member Joined Mar 16, 2009 Messages 17 Use a clay bar, it should take away some of the roughness. it takes time and some elbow grease but as i said beore, should make it better
Mar 22, 2009 #5 B Boston GN Well-Known Member Joined May 24, 2001 Messages 1,987 GNBRETT said: I would not recommend a wet sand on ur own if ur not familiar doing it. I would definately start out with a good clay job tho. Click to expand... Agreed 110% Grab a clay bar and use that. Basically you rub along the paint while keeping it lubricated and this will remove embedded junk in the paint. Next, grab a buffer and some polish and have at it. There's another post in this section where I posted my favorite paint care products. That should help get you started too
Mar 22, 2009 #6 T turbopete Tug Driver Joined Jun 28, 2002 Messages 903 Clay bar With alot of soapy water so the clay slides easily. If you use dawn liquid soap, it will help strip off the old waxes and oils that are on the paint.
