How do you connect 3 accel boxes to one coil pack?
rob86gn said:
I've also gone thru about 3 coils and 2 modules. The miss goes away (with new coil) until the car is hot, it seems, and then starts to miss. Once it starts to miss it will always miss until I replace the coil. Then the problem starts all over again. Runs good, get it hot, misses, etc...
Are you using the type II stuff or the type I? You need to get youself the caspers tester,$119 before you go insane.
I am using type I. The coil and module seem to get really hot. I guess I could get the coil tester but I was just wondering if those accel coils hold up to heat better because heat seems to be the ultimate problem in my case.
