Feb 24, 2012 #1 B BOP4ever Member Joined Jul 6, 2007 Messages 892 I took the 4 bolts out the bottom 10mm, but it seems stuck and I don't want to beat on it any more ! A picture would be so nice !
Feb 24, 2012 #2 R ronbuick Active Member Joined Jun 12, 2001 Messages 1,587 +remove oil filter, two bolts are there
Feb 24, 2012 #3 B BOP4ever Member Joined Jul 6, 2007 Messages 892 ronbuick said: +remove oil filter, two bolts are there Click to expand... I did that and I don't see any bolts just the center thing the filter screws on and a little pressure bypass valve..... No screws visable.
Feb 24, 2012 #4 S S10xGN RETIRED! Joined May 26, 2001 Messages 2,563 BOP4ever said: I did that and I don't see any bolts just the center thing the filter screws on and a little pressure bypass valve..... No screws visable. Click to expand... Well, if you can't see 'em the cover won't be coming off in one piece...
Feb 24, 2012 #5 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 Do you still have the cooler adapter on? If so remove that (the center threaded piece that the filter screws on) once that is off you will see the other 2 screws!
Feb 24, 2012 #6 D DCVING 6 Well-Known Member Joined Jul 11, 2002 Messages 4,433 Hope this works for you. Should be able to see the 6 bolt locations here. Attachments DSCN0143.JPG.jpg 278.6 KB · Views: 92
Feb 25, 2012 #7 Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Messages 16,520 Buy a shop manual....
Feb 25, 2012 #8 T turbofabricator Well-Known Member Joined Mar 7, 2004 Messages 4,261 You MUST remove the oil cooler adaptor. Takes a BIG socket to do that. You will then see the two bolts behind the oil cooler adaptor.
Feb 25, 2012 #9 B BOP4ever Member Joined Jul 6, 2007 Messages 892 Got it ! Thought it was one piece . Thanks!!
