How do you pick a stall speed?
GregP
For new car, never run so no prior baselines. How to make a first guess.
Wt ~ 2800#
Gear = 4.86:1
Tires = 29.5 x 15.50
HP ~ 550 @ 6000
TQ ~ 560 @ 4500
Thanks - Greg
Not enough info.
In order to accurately pin down the best converter for your needs, much more information is required. Instead of retyping everything, take a look at the application chart that we utilize at TCI.
Ok, more info
Engine:
408 cu in SBC
4.165 x 3.75
11:1 compression
252*/262*@.050 .630/.630 solid roller
AFR 220 Race heads
Hilborn splayed stack 8-port w/ Accell Gen 7 DFI
1 7/8 primary headers, 3 1/2 collectors and side exhaust
Front and mid motor plate mounts (mid is 0.090 steel)
Car:
65 Corvette (sorry, not a Buick but you guys seem to have the most knowledge on the 200-4R trans hands down) Photos etc are at http://corvetteforum.net/classics/gregp/65corvette.htm
back half tube chassis
stretched wheelbase
4-link rear
Fab 9 w/ locker 4.86:1 35 spline axles
full cage
Trans:
200-4R (whose not yet finalized)
Expect shift points 6500
I plan to discuss selection with the trans vendor(s), but always like to know as much as I can going in to help in asking the right questions (and filtering any BS if some happens along).
-Greg
Thanks for the reply. It seems that most people I've talked to are in the same area, around 3500 stall. I want the car to be able to cruise with the local Corvette club, and of course make the long idle down the boardwalk in Ocean City once a year. It will be raced at the all Corvette drags a couple times a year. The rest of the time it's just for fun runs on a nice sunny day.
Thanks - Greg
