How does this piece come off?
larry33kc
There is a piece under the header panel that bolts to the top off the core support. How does it come off is there some hidden bolts I'm not seeing?
I have all the bolts that I can see on the top off and it seems loose but it won't come out.
Thanks Larry
Are you trying to take the header panel off?
ok I see what you trying to do... That is part of the header panel. If your trying to get in that area take the grill insert off
Oh come on. I couldn't have any worse luck. Thanks I will bolt it back up and go a different direction.
Yeah that long bracket that goes the length of the core support there is seam sealer on it. it can be pulled off but not when the header panel is still bolted up.
