SignUp Now!Originally posted by Homebuilt
Mine has a stock turbo, no intercooler, street gears, and has run deep into the 12's.
Why are you referring to Turbo when Chad what's his name answered your original post??? My car isn't broken and wasn't broke when it ran a 12.31. LOLOriginally posted by lrover2
Easy Turbo! Just an observation. Just wondering if the hot air cars had allot of issues. And maybe I do like the smell of cow dung. It makes for good BBQ parties.![]()
First off if your the dude that worked for Dell, seems to me either he was telling stories or you left out a little about your build. I know he mentioned a larger turbo and something about you changing the compressions on your motor? Seems these weren't mentioned? Just clarification of what you said. I'd be real interested to see this run at Mid Michigan.Originally posted by Homebuilt
As far as my combo, here it goes! Bought my GN late fall last year. Complete with engine noises and a broken trans. 2000.00
investment. orginal block, .040 over stock replacement cheepy joe
8$ a piece pistons, I reconed the stock rods with arp's. fresh crankshaft grind, cut my intake apart, ported/flowed. Ported/flowed my stock heads, new springs, 3 angle valve job, 5 angle was no improvment! new oil-pump, rollerchain, clevite bearings, KennyBell 1TXB camshaft, goodwires, friend burned prom, homemade single exhaust, 3:73;s. rebuilt trans, no "shift-kit" bull****. Hey even spins tires in overdrive!! HP-BU15 RECON converter, good wires, new plugs, homemade cold air set-up with K/N filter, homemade 3in up-pipe, homemade 2/1/2 cross-over, 3 inch sigle enxhaust with 1 of a kind muffler. With street tires, and I mean 15 street tires, it went a best of 12.41@106mph, with a real slippery 2.23 60ft.
