How fast on a dutt neck?
streetknight
DCVING
What should I expect with this new mod? I went 11.71 @ 113MPH with the stock IC. Now I have the dutt neck and alky.
TIA
Take it to the track again and let us know, then we will have some real numbers to go with :D
TIA
Really curious---reading your post it appears you went 11.71 on pump gas(before adding alky) with a stock IC.If so---that is flying---what kinda boost?---stock longblock?
Really flying---great if you did!!!!!!
Geoff
The combo of both work really well together. I put alky on and ran .2 faster in the 1/4. Dutt neck install gave me about .1-.2 @25psi
My car really picked up with Eric Marshall chip .5 :eek:
Report back with times.
Bo
Correct me if I'm wrong but isn't the stock IC and impediment after a certain point...diminishing returns after 12's? :confused:
Don't wanna mislead fellows. I went 11.70's with race gas and 25psi.
Now I'm running alky and I heard with it the intercooler could be put on the back burner cause of the cooling effect of the alky. Can't afford a bettter IC right now is why I was wondering about the dutt neck.
Thanks again everyone.
PS- Matt give me an email, I need to ask you a couple ?'s
If you're just putting the neck on a stock intercooler then you'll probably pick up some HP. Not too much though. I've got the Dutt neck on the intercooler in my Malibu. It's been down to mid 6's @ 107 in the 8th, BUT it was on an extended intercooler.
Update..
Been working on the car and IC. I'm hoping this Sunday I will get some track time. The car now has been mocked up where it won't be a big problem to change IC's at the track.
Hopefully, we will get to make a few passes with a stock IC, the new dutt neck IC, AND I just got a friend to let me borrow his V4.
If all goes well we will do some back to back testing on the same car, same track, same day.
Wish me luck and if anyone has any pointers before I go please post.
Gonna post this in the appropriate forum for anyone in my area that might wanna come help or hangout.
Please let us know what you get from adding a neck to the stock IC with the alky- Im going to guess .1 and 1mph-
Id really like to know because ive got the stocker on my daily driver.
BW
