How fast with this turbo?
my1stgn
I have the trubo listed below. I believe its a GT61 DBB turbo.
http://www.fullthrottlespeed.com/itemdesc~CartId~{5E2C89D9-704B-4031-EVEREST8ED6-8D42DCCB8D79}~ic~628GTB6176~eq~~Tp~.htm
Anyone running this and what times should I expect? Supporting mods are
-304 Walbro fuel pump, hotwire kit, 60lb mototrons, Accufab AFPR
-Razor Alky w/ TT Alky Chip
-Dutt Kneck Mod
-LS1 Maf with 3.5" Intake K&N
-RJC Power plate
-2 3/4 Exhuast w/ test pipe and dump tube
-3" THDP
-Poston Header's
-BstC Controller
Thats all I could think off now but I also have (not yet installed) LC1 Wideband o2 sensor and I wanted to go with the extender chip. Dont have slicks or drag radials but that will be my next mod. Other mods Im considering are
-Weld Drag lights w/ M/T Slicks
-Easton Posi Unit
-Higher Stall convertor
-Built Tranny
Out of these mods, which one should be next. Im thinking Slicks, Posi, the trans and convertor.
Mandatory to have slicks, and a posi. As far as the tranny goes I ran a stocker with just a shift kit deep into the 11's before it broke..
As long as you have a shift kit it should be okay for now. :eek:
Yes, you need to get a better intercooler and then i will guess you should run 11.50's at 115.
I think the best mod. i have made to my car this year was the precision intercooler.
I just ran a 11.39 @ 118 mph with a stock suspension with 2 airbags and a pinion snubber with a TE60 turbo, precision stock loc. I/C, and a 3" downpipe with the basic upgrades. Bone stock engine.:D
Im using a 3000 orange stripe stall from the buick club with a mildly built trans. with a shift kit. Im pulling 1.60's sixty footers.
you will have plenty of power but you have to make it hook or it will do you no good at all. My car with a shift kit, two airbags, stock converter, and BFG DR. and all stock motor 12.9@108 1.75/60ft. If I would have had a bigger turbo and inj. that combo shoud have went low 12 maybe 11.99 on a real good day. anyway just keep this in mind.
1. MAKE POWER!!!
2. USE POWER!!!!!!
3. REPEAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I hope in some way this helps.
