How many inputs possible with PL/SD2
achalmersman
Im thinking the only answer to my question is XFI. I have PL, SM, SMG, and SD2 (currently using TT 6.1) When I go SD2 I would love to be able to log more. Is there any way to reconfigure things like the EGT input on the PL board to log more stuff? Is there any way to create an extended AUX board for more inputs? Currently I am logging MAP with a SSI 3.5bar sensor from Bison, and fuel pressure. I would like to log the following.
3.5 bar MAP
Fuel Pressure
Alky Pressure
Turbo Drive Pressure
Pre-Intercooler Pressure
Oil pressure
Trans Line Pressure
Trans temp.
Any solutions to add more (maybe not all) using the PL setup? How many inputs can you log with XFI?
Sent from my VS990 using Tapatalk
the egt input can be reconfigured, so, 5 total.
map afr and 3 more. There is no easy way to add more at the moment, but let me think about it....
Bob
Bob
Awesome Bob! Do I need to email you for any special instructions on how to reconfigure the EGT?
send me an email.
the electrical connection would be the same as the other inputs. I need to change the software to treat it like inputs 4 and 5.
Bob
