Hydroboost Conversion
The Hydroboost Brake Booster Runs Off Of Power Steering Pump Pressure. No Vacuum Involved. Guys On This Forum Have Reported Building 22lbs Of Boost With Their Foot On The Brake. As The Revs Come Up, So Does The Pump Speed. It Just Holds The Brakes On Harder. These Units Can Deliver Up To 2000psi To The Calipers. When The Brake Is Released, The Pump Is No Longer Under Load, And Does Not Affect Horsepower. Building Manifold Pressure Against A Vacuum Booster Will Cause It To Let Go. Vacuum Boosters Need Vacuum To Work, And Supercharging Is The Opposite Of Vacuum. A Drag Race Start On A Gn Requires The Rpm's Come Up To Spool The Turbo. Most Cars Will Red Light At 1-3 Lbs Of Boost With The P/m Or The Standard Regal Booster.
