Jan Larsson
- Nov 22, 2001
Not sure how much all your engines "jump around" in the engine bay when you put it in reverse but mine really moves so want your opinion if this is normal or not.
I got all new motor mounts and trans mount (after market rubber style so should be close to OEM mounts), nothing is loose (bolts etc) ...
I took two movies where I rev the engine a few times and then go from park to reverse 3 times in total and you can really see the engine move around ... let me know if this is normal or if I should start to trouble shoot???
YouTube - TTA 1078 Engine moving when revved and put in reverse ...
Appreciate your views / comments / suggestions
