How much dose posi track help...
DrkBluT-TyPe
1986 Buick Regal T-Type
Well I'm getting alot of stuff done to my Buick this week...being alot for me. A raceing chip, tuneing, posi track being put in, and fixing the broken wheel stud. My question is, is it a BIG difference from the single peg leg I had before?
For any drag racing your Buick will need traction & the posi will help as a good set of tires that BITE.
But here is some food for thought: my NON posi 86 all stock GN ran a 13.7. with a set of drag rads.
Otherwise you will find yourself rolling out alot cause sitting still at the starting line is no fun when you see the other car woosh out of the gate.
My newtoy 87 TURBO T has posi & the street tires will break loose almost at any low speed. I still have to roll out.
The more power your car makes the worse your traction problem will be without Posi.
