Apr 2, 2011 #1 B BOOSTD1 Member Joined May 9, 2006 Messages 465 How muck Rwanda HP will it take to get a low 10 on a 3400 car. Have good suspension. And transfer. Still looking for a low 10 high 9 combo
Apr 5, 2011 #3 R RJ REYNOLDS Member Joined Dec 16, 2003 Messages 285 Is that 3400# with driver? If so, you will need closer to 675 RWHP. If that does not include the driver you will need more HP.
Apr 5, 2011 #4 G gn4u2c Yes Its fast no you can't Joined May 26, 2001 Messages 1,653 ET Calculator or http://www.wallaceracing.com/et-hp-mph.php
Apr 5, 2011 #5 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 BOOSTD1 said: How muck Rwanda HP will it take to get a low 10 on a 3400 car. Have good suspension. And transfer. Still looking for a low 10 high 9 combo Click to expand... 625whp will go 10.0 with a 1.45 60' at 3400lbs unless your converter isn't efficient enough.
Apr 5, 2011 #6 T turbocliff I Slang in my white T Joined Jul 5, 2004 Messages 1,358 I went 9.6X-9.7Xs with 620rwhp at 3380lbs with 1.39 60s. Of course dyno numbers are just dyno numbers....
Apr 5, 2011 #7 B BOOSTD1 Member Joined May 9, 2006 Messages 465 turbocliff said: I went 9.6X-9.7Xs with 620rwhp at 3380lbs with 1.39 60s. Of course dyno numbers are just dyno numbers.... Click to expand... What's your combo on them runs if u don't mind
Apr 5, 2011 #8 T turbocliff I Slang in my white T Joined Jul 5, 2004 Messages 1,358 BOOSTD1 said: What's your combo on them runs if u don't mind Click to expand... That was what I ran with basically a TSM combo on low boost. 109 block 349ci stroker Solid Roller ported GN1s Ported stock intake 70mm TB 96# injectors ATR Headers 3.5" DP and 3.5" single shot exhaust BA Front mount cooler 70GTQ turbo TH350 Trans with PTC converter 8.5 Rear 3.42 gear XFI At the time, my car made 620 at the tire on base boost (16psi) and 756rwhp at 28psi. At 16psi off the wastegate spring the car would go 9.60s-9.70s at 136-137 like clockwork, and at 28psi it went 9.30s at 147 like clockwork.
Apr 5, 2011 #9 T tsm3089 Member Joined Nov 11, 2006 Messages 285 349 ci !!!! I knew that thing was not tsm legal :biggrin:
Apr 5, 2011 #10 T turbocliff I Slang in my white T Joined Jul 5, 2004 Messages 1,358 Typo... 249... i think.
