christians87
 - Jul 23, 2007
How would you verify if it is the maf? Would'nt the car still try to make more than 7psi; my car will not builld anything more than 7psi. Line off fuel pressure is usually 38psi. It doesnt really go up much at all when i remove tha vaccum line. I am not sure of the actual chips brand but I do know that on the back of the chip it says, First line: August    28#
Second line: 20* 17# 93oct
On the top of the chip it has a yellow smily face sticker. Like this
As for the fuel pump, what brand and model should I with? I've already had bad luck with a walbro 255 that died on me after only 3 months use
!! Im about to go outside now and check the turbo now.
